How to Use Mesh Fill
This tutorial has been written for CorelDRAW® Graphics Suite X7. While similar features might be available in previous releases, the tutorial will be fully applicable to CorelDRAW Graphics Suite X7 only.
Applying a mesh to an object
A mesh fill can be applied only to closed objects or a single path. If you want to apply a mesh fill to a complex object, you must first create a mesh-filled object and combine it with the complex object to form a PowerClip object.
Let’s start with an object, such as a flower petal in the image I created. We are going to draw an ellipse using the Ellipse tool (F7) from the toolbox. Then from the Object menu (Arrange menu in CorelDRAW X6 and earlier), we will select Convert to Curves (Ctrl+Q).
Next, use the Shape tool (F10) to move the control handles to create the shape that you want. (Fig 1)
Now, we are going to give the shape a fill. I‘ve used the Interactive Fill tool (G) to create a linear fountain fill. Then, I removed the outline on the object by choosing None from the Outline width list box in the Outline section of the Object Properties docker. (Fig 2)
  1. In the toolbox, click the Mesh Fill tool RtaImagef414 (M).
  2. Type the number of rows and columns in the Grid Size boxes on the property bar, and press Enter. I used values of 2 horizontally and 4 vertically. (Fig 3)
  3. You can then adjust the grid nodes much the same way that you would adjust the nodes of a curve with the Shape tool (F10).
You can add intersecting lines by double-clicking in a space, or you can add a single line by double-clicking a line. If you double-click intersecting lines, they will be removed.
2014-11-14_1532
Dragging a color from the color palette and dropping it onto an area bounded by mesh lines will cause the color to completely fill the area and blend into the surrounding areas. When dropping the color on the node, the color will blend from that point outwards.
Smoothing the colors in a mesh fill
If the mesh object contains color, adjusting the intersection nodes of the mesh affects how the colors blend together. This can be changed or adjusted with the Shape tool.
To smooth the appearance of color in a mesh fill, select a mesh-filled object, select the Mesh Fill tool in the toolbox, and click the Smooth Mesh Color button RtaImage7042 on the property bar.
Applying transparencies to a mesh fill
You can also add transparency to a mesh fill. For example, you could place a texture or other object behind the mesh and adjust the transparency of a node or group of nodes with the Transparency tool.
  1. Select a mesh-filled object.
  2. In the toolbox, click the Mesh Fill tool.
  3. Click a node to select part of the mesh.
  4. On the property bar, move the Transparency slider to the right to increase the color transparency
To complete our design, I created a shape for the vase, applied a mesh fill with a grid of 7 vertical x 2 horizontal, and dropped in the colors that I wanted.
CorelCONNECT
To copy this mesh to another object, select the target object — in this case, the top of the vase — and click the Copy Mesh Fill button
CorelCONNECT on the property bar.
This will copy the mesh that I have created. Next, I simply add transparency to the vase, as I did to the flower petals, and then I put everything together.
CorelCONNECT
In no time, you’ll be using mesh fills to design with creativity and confidence.
We hope you found this tutorial helpful and we would love to hear your feedback in the Comments section below. And don’t forget to visit our social media pages and show us what you’ve learned by sharing your photos, videos and creative projects with us.
Want to try out CorelDRAW Graphics Suite for FREE?
Download your FREE 15-day trial to see what’s new in CorelDRAW Graphics Suite and explore a world of new creative possibilities in graphic design, photo editing and website design.
Related Tutorials
Tools You Need
CorelDRAW Graphics Suite 2017
Combine your creativity with the power of CorelDRAW Graphics Suite to design graphics and layouts, edit photos, and create websites.
Valentine’s Clipart
Love is in the air! Spice up your photo and graphics projects with the Valentine’s Clipart Collection.
CorelDRAW Home & Student Suite X8
A complete design suite for home and students. Edit photos and create reports, drawings, flyers, ads, business cards, logos and more.
Wacom Intuos Pro Medium
With plenty of room to sketch, paint and design, this medium-sized tablet is a popular choice for artists and designers.
Related Images
Share this post
Leave a Reply
Your email address will not be published. Required fields are marked *
