Using Special Effects
By Discovery Center Team
This tutorial was created in PaintShop Pro X5, however if you are using a later version, you will find the tools in the same locations as indicated in the video.
Watch and learn how to apply several special effects to your photos in PaintShop Pro. Adding special effects to photos is not only easy, but it’s a fun way to experiment with altering your images.
This video will teach you how to use the following special effects:
  • Use the Selective Focus tool to create a depth of field effect and increase saturation
  • Apply Sepia Effects to give a flare of retro to an image
  • Use the Time Machine effects
  • Create a Vignette Frame three separate ways
Download the sample images to follow along.
This tutorial will show you how to apply several special effects to your photos in PaintShop Pro. Adding special effects to photos is not only easy, but it’s a fun way to experiment with altering your images.
You will learn how to:
Selective Focus
Selective Focus is a great way to make part of an image stand out from the rest. This is also the tool of choice if you have been considering creating a desktop wallpaper from one of your photographs.
1. Open the image in PaintShop Pro and make sure that you are in the Edit workspace.
2. From the Effects menu select Photo Effects and then Selective Focus.
The Selective Focus tool is quite versatile, allowing you to select an area of an image to focus on using a linear, circular or freehand selection option.
In this example, we will use the circular selection tool as it allows you to adjust the shape to create an oval around the Ladybug.
4
3. With the Preview on Image checked, changes made in the Selective Focus window can be seen on the image below.
4. You can increase the Blur tool to make the background as blurry as you like. By increasing the Feather Edge, you are creating a more gradual fade from the sharp portion of the image to the blurry portion; a large feather will create a smoother look.
5. Saturation is an option seen in many areas throughout PaintShop Pro and it is also available through the Selective Focus tool. If you do not wish to increase color saturation, set this value to 0. In this example, the saturation will be set to 60 to give the image a more vibrant appearance.
6. When the adjustments have been made, click OK. Depending on the system you’re running, it may take a couple of seconds for the changes to be applied to the image.
5
Sepia Toning
If you enjoy taking photos of antiquities or have a special image representative of history, such as photos taken at historical sites, museums or events, the Sepia effect can give these images that retro edge that will make them really stand out.
6
1. Click on Effects >Photo Effects > Sepia Toning.
7
2. Make sure that there is a check mark in Preview on Image.
8
3. Adjustments available for Sepia range between 1 and 100. At the lower end of the scale is black and white, the higher end of the scale will add more copper to the appearance. In this example, we will use 75%.
4. When you have finished, click OK and the effect will be applied to the image.
9
Time Machine
A similar effect, unique to PaintShop Pro is the Time Machine, which not only allows you to mimic photographic styles throughout the last two centuries, it also gives you a history lesson while you use it. For this example, we will be using a photo representative of time to demonstrate these effects.
10
1. For the Time Machine effect, go to Effects > Photo Effects > Time Machine.
11
2. When the Time Machine window opens you will be able to see a range of photographic styles from 1839 till 1960 and seven examples of how your photo would look if it were processed using these various techniques throughout the ages. As you click on each thumbnail, the name will appear below, followed by a brief description of the period when the processing was used and how the development processes took place. With Preview on Image selected, you can see the changes take place on your image as you click on each thumbnail.
12
Photo edges are meant to represent the styles of paper commonly used with each processing style and you can choose to turn these edges on or off. In this example they will be left on.
3. When you have made your selection, click OK to continue.
13
Vignette Frame
There are three quick and easy ways to create a Vignette Frame around your image and which is the best way is simply a matter of personal preference.
Method 1: Delete the outside portion of the image, leaving behind the frame.
1. Select a background color from the Materials palette
14
2. Choose the Selection tool from the Standard toolbar.
15
3. In the Interactive Properties toolbar, select Ellipse from the selection types and set the feather to 50.
16
4. Draw an ellipse around the area of the image you wish to frame.
5. Go to Selections and then Invert Selection.
17
6. Hit the Delete key on your keyboard. This will replace the selected area with the background color you have chosen from the mixer.
18
19
Method 2: Create a new layer which will serve as the frame and then remove the center portion to show the image behind it.
1. Go to Layers and select Create New Raster Layer.
20
2. Give the layer a name and click OK.
21
You will see the new layer appear in the Layers palette on the right side of your screen. If you do not see it, click the F8 key on your keyboard to view this palette.
22
3. From the Standard toolbar, select the Flood Fill tool and click on the image.
23
4. To see the image better so that you can be sure to cut out the correct portion of the frame, you can adjust the opacity of the layer at the top of the Layers palette.
24
5. Choose the Selection tool from the Standard toolbar. Once again, make sure that Ellipse has been chosen from the Selection Type in the Interactive Properties bar.
25
In this example we will set the feather to 100 so as to make more of a gradual fade around the inside edges.
26
7. Now you can increase the opacity of your frame, either partially so that some of the image shows through, or all the way back to 100% (full opacity).
27
28
Method 3: Use the pre-made picture frame, “”Antique Vignette””
1. Click on Picture Frames under the Image menu.
29
2. After you have selected the frame, you have the option to choose to frame just that layer, the entire project, place the frame inside the image, or outside the image (which will include a border). The frame can also be flipped, mirrored or rotated. For the purposes of this example, we will leave the settings to frame the entire canvas, outside the image, and rotate to the right.
30
3. When you have finished choosing the settings, click OK and the frame will appear as a new layer, titled Picture Frame in the Layers Palette.
31
Like the previous example, this frame is a layer on top of the image, the opacity can be altered so as to show part of the image through the frame. One drawback to this method is that the color of the frame cannot be changed. However, the benefit is that it is quick and consistent from one image to the next; so if you are planning on creating an album of multiple photos which will all have a vignette frame, using a Picture Frame is the ideal choice. Another note is that this particular frame is pure white so when the final image is complete it will give the illusion of a transparent background if used on stationary, plain labels or on a web site with a white background (as shown above).
Thanks for watching! We hope you found this tutorial helpful and we would love to hear your feedback in the Comments section below. And don’t forget to visit our social media pages and show us what you’ve learned by sharing your photos, videos and creative projects with us.
See what's new in PaintShop Pro 2021!
Download your FREE 30-day trial and discover a world full of creative possibilities with PaintShop Pro 2021, your all-in-one photo editing and design software.
Related Tutorials
Tools You Need
PaintShop Pro 2021
Discover a world full of creative possibilities with PaintShop Pro 2021, your all-in-one photo editing and design software.
Color Punch Scripts
Get a huge pop of saturated color with these 3 PaintShop Pro scripts that will create bright and dazzling photos in 2-tone color schemes.
PaintShop Pro 2021 Ultimate
Enjoy a faster, easier, more creative photo editor PLUS an exclusive bonus collection of premium software.
Gradient Scripts
With this collection of PaintShop Pro scripts, you can instantly add colorful gradient effects to your photos. Choose from 10 different color schemes.
Related Images
Share this post
Comments (4)
  • W David Mahan Reply
    There is one drawback to this tutorial…..Where is the lady bug image file to work in the exercise? Providing a link to it would make this tutorial muck more valid!!!!!
    January 27, 2018 at 3:59 pm
    • gilliandarby Reply
      Hi David,
      Thanks for your comment. A link has been added to the tutorial description at the top of the page to download sample files you can use to follow along with the tutorials.
      Hope this helps!
      The Discovery Center team
      February 2, 2018 at 3:38 pm
  • Lee Pulsipher Reply
    Where can I find oval or elliptical photo frames for vignettes in PSP 2018 Ultimate? These frames were available in at least some earlier versions of PSP since I used them in projects in 2008 & 2012. In PSP 2018 Ultimate I can only find rectangular frames!! Not good!!– Also same problem in PSP X9, still on my desktop. I am too old to manually draw a nice ellipse or oval. HELP! I’ve used PSP since at least PSP pro X3.
    January 20, 2018 at 6:52 pm
    • Adam Reply
      Hello Lee,
      It is possible these photo frames were not included in PaintShop 2018. If you have the frames on hand from another program, you can always add additional content such as frames, plugins, picture tubes, patterns, and more using these instructions:
      https://learn.corel.com/blog/how-to-use-third-party-plugins-in-paintshop-pro/
      Hope this helps!
      February 3, 2018 at 5:37 pm
Leave a Reply
Your email address will not be published. Required fields are marked *
Get a FREE creative pack!
Sign up for our newsletter and get a free creative pack plus the latest tips, tutorials, and special offers in your inbox each week.
You have successfully subscribed! Check your inbox for your email confirmation and free creative content pack.
