By Melissa Gallo
Value is the lightness or darkness of a color or tone, and the value structure of your painting is what will make it succeed – if the values are off, your colors won’t look right. In this tutorial, we’ll show you how to create a value map that will be used alongside the reference image to create your painting.
To make a value map, you need to summarize your image into 4 to 6 values by grouping similar values together. The first step is turn your reference image into a black and white image. Open the Auto Painting panel and select Underpainting, then use the Saturation slider to desaturate your image completely. Next, open your Layers panel and create a new layer so you are not drawing on your original image. On this new layer, use your brush to draw outlines around the different light and dark areas. Finally, create a second new layer, and sample the different areas using the Eyedropper tool, then use your brush to fill in the outlined areas. And now you have your value map!
Download your FREE 15-day trial for Windows or Mac and venture outside the lines with realistic brushes, exciting media, and an array of versatile tools.
Fine Art for Beginners
Getting Started with Painter
What’s New in Painter
Painter 2023
Ultimate Brush Pack Vol. 1
Painter Essentials 8
Ultimate Brush Pack Vol. 2
