Create a Calendar
Create a Calendar
By Discovery Center Team
Creating unique personalized calendars is one of the many fun projects you can do using CorelDRAW. This tutorial will teach you how to create a custom calendar in a few simple steps.
You will learn how to:
  • Use the Calendar Macro to create one of many different styles of calendars.
  • Import an image into CorelDRAW.
  • Use the PowerClip tool.
RtaImagea0b8
What You Will Learn
  • How to use the Calendar Macro to create one of many different styles of calendars.
  • How to import an image into CorelDRAW.
  • How to use the PowerClip in CorelDRAW Graphics Suite X6 and previous versions of CorelDRAW.
Preparing the Document
The hardest part about creating a calendar in CorelDRAW is deciding on the document size. Once you set the page size, the script will take care of the rest, whether it is for the back of a business card or a 4-feet panel highlighting monthly specials.
The script that is included with CorelDRAW is capable of creating a calendar almost any size that you may require; it is just a matter of setting the page size and then configuring the proper settings.
RtaImage4232
3. When the Run Macro dialog box opens, from the Macros in: drop-down (at the bottom of the dialog), select CalendarWizard(CalendarWizard.gms) and click Run.
Using the Calendar Macro
4. Looking at the interface, the top left corner lets you select the year and the specific months. Click the All button in the upper right if you want to create an entire year. Below this is the Language drop-down menu.
5. Under Layout, you will see a number of different layouts. Experiment for a moment and then select Year: Image + 12 Small [Bottom Bottom].
6. On the Page Layout tab, click the button that reads Adjust Fonts. This will automatically adjust the fonts to fit within the various regions. Alternatively, you can select the Small: Header and Small: Body tabs and manually adjust them. You also have the ability to select the color of the text.
RtaImagec047
7. After you are happy with the settings, click the Generate button. It will probably take no more than about 15 seconds until you see the message Finished Generating Calendar; then click OK and select Close.
Creating a PowerClip
8. Now it is time to dress it up. Resize the larger gray rectangle to 10″ by 8″ using the Pick tool and place it toward the top of the page. This will leave space to add your logo, address, and the year.
RtaImage6203
12. Select the bitmap and select Effects > PowerClip > Place Inside Container. Use the large black arrow to click on the gray rectangle.
13. If your image seems to disappear and you see an empty frame, do not worry. A Powerclip is like a porthole where you can hide items behind it. If the image does not sit in the middle of the porthole, you wont be able to see it.
14. With the frame selected, from the Effects menu, select PowerClip > Edit Contents. Now you will be able to see the image and the PowerClip frame. Drag to position and size the image where you would like it and then from the Effects menu, select PowerClip > Finish Editing This Level.
Adding a Background
15. Once your image is inside the PowerClip and centered where you want it, the final step is to add a background.
16. By double-clicking on the Rectangle tool, you will create a page frame the size of the page that will be placed behind other objects in the document. Select the Eyedropper tool from the toolbox and pick a color from within the image and then click the rectangle that you just created. You can also give your calendar a title or import a company address and logo to use in the space below the image.
17. Now, its now just a matter of printing out a proof, and if everything is OK, send it off to the printers or copy center.
RtaImageaf1b
Thanks for watching! We hope you found this tutorial helpful and we would love to hear your feedback in the Comments section below. And don’t forget to visit our social media pages and show us what you’ve learned by sharing your photos, videos and creative projects with us.
Want to try out CorelDRAW Graphics Suite for FREE?
Download your FREE 15-day trial to see what’s new in CorelDRAW Graphics Suite and explore a world of new creative possibilities in graphic design, photo editing and website design.
Related Tutorials
Tools You Need
CorelDRAW Graphics Suite 2017
Combine your creativity with the power of CorelDRAW Graphics Suite to design graphics and layouts, edit photos, and create websites.
Valentine’s Clipart
Love is in the air! Spice up your photo and graphics projects with the Valentine’s Clipart Collection.
CorelDRAW Home & Student Suite X8
A complete design suite for home and students. Edit photos and create reports, drawings, flyers, ads, business cards, logos and more.
Wacom Intuos Pro Medium
With plenty of room to sketch, paint and design, this medium-sized tablet is a popular choice for artists and designers.
Related Images
Share this post
Comments (2)
  • jess Reply
    I’m wondering is this available on X8 because I have tried to follow this tutorial however there are no macros in the drop down bar.
    May 13, 2016 at 6:50 am
    • adampotter Reply
      Hello Jess,
      It is, although the tool has changed slightly between CorelDraw editions. There is a free calendar creator extension available for CorelDraw X8, which you can find in the Get More docker.
      The easiest way to get to this is from the welcome screen that appears when you first open CorelDraw – just click on the Get More entry at the bottom of the list, and click the Get More button that appears.
      This will open a new docker on the right side of your workspace; click on ‘Extensions’ in that docker, and select the calendar!
      While you have the Get More docker open, feel free to browse through the rest of our library of additional tools, features, and extensions. Many of them are free, and we are sure there will be something else that catches your eye!
      All the best,
      Corel Discovery Center Team
      May 13, 2016 at 10:24 am
Leave a Reply
Your email address will not be published. Required fields are marked *
