With the GIF creator introduced in VideoStudio 2022, you can capture a section of your video and convert it to a short, repeatable clip. GIFs are a great way to share highlights, over-the-top moments, and even cringe-worth content across all online platforms. Go ahead and explore this fun new tool and produce your own unique GIFs for expressing emotions and reactions. Just select the best scenes from your footage, export them into GIF format, and easily share with anyone. Their size makes them easy to upload, email, or send over SMS. It’s the best way to feature your most unique frames in a flash.
Learn how you can use the GIF Creator in VideoStudio for optimizing your GIF file size for easy sharing across social media! This tutorial will help you learn how to crop your selected clip to reduce the estimated file size for your GIF, how to speed up or slow down your clip, and how to adjust the frame size and frame rate. When you’re happy with the results, just drag and drop your GIF to wherever you want to share it.
Learn how to take your GIFs to the next level with text animation! Explore how to breathe new life into the motion of your text –flying in, fading in, or moving in different directions. Take creative control down to each character of your titles! Select font styles and colors to suit your GIF and enhance your impact further with customized motion and zoom effects. This tutorial will show you how it’s done.
Download a FREE 30-day trial and turn your best moments and life experiences into unique movies with this easy and fun video editor packed with intuitive tools and creative effects.
What’s new in VideoStudio
Capture, import and export
Templates, overlays and graphics
Featured products
VideoStudio Pro 2023
Studio Backlot Membership
VideoStudio Ultimate 2023
Vision FX 2.0
How to create an animated GIF
You can convert video clips to animated GIFs by using the GIF Creator. You can select a video clip from the Timeline or navigate to the file you want to convert. You can trim the selected clip to convert only the frames you want.
Do one of the following:
- If the clip you want to convert is open in the Timeline, select the clip.
- If you want to convert a clip that is not currently in the Timeline, ensure no items are selected in the Timeline.
On the Timeline property bar, click the GIF Creator button.
- If you selected a clip in the Timeline, the clip appears in the GIF Creator window.
- If no clip was selected, navigate to the video clip that you want to use and click Open.
If you want to trim the clip, use any of the standard trimming tools in the GIF Creator window. Use the playback controls to preview your changes.
In the GIF Creator window, adjust any of the following settings:
- Selected area — If you want to use a specific area of the frame for your GIF, drag the orange bounding box in the preview area to enclose the area that you want to use. In the Size area, you can fine tune the dimensions by typing values.
- Speed — Set the playback speed.
- Reverse — Mark this check box to reverse the start and end of the clip (backwards).
- Frame Size — Choose from Same as selected area, Standard, or Custom, choosing values if required.
- Frame rate — Set a value for the frame rate. Higher values result in a smoother animation, but also a larger file size. Lower values result in a choppier animation and a smaller file size.
The New Clip Duration and Estimated File Size values update according to your settings.
Click Export to generate the animated GIF. The file is added to the Library automatically.
