The Fit Objects to Path command in CorelDRAW gives you the ability to fit any type and number of objects to a path of your choice. Smart distribution and rotation settings help you customize the placement of objects on the path. In this tutorial we’ll show you how to distribute objects along a path by placing equal gaps between them, how objects can be rotated to follow the path, and how to use additional options such as different rotation styles and spin angles to create unique effects.
NOTE: this tutorial was recorded in CorelDRAW X8. For other versions of CorelDRAW, including subscription, you can find the Fit Objects to Path command under the Object menu or by opening the Fit Objects to Path docker (Window > Dockers/Inspectors > Fit Objects to Path).
Start your FREE 15-day trial and embark on a design journey with powerful tools for vector illustration, layout, photo editing, typography, and collaboration.
What’s new in CorelDRAW Graphics Suite
Objects, layers, and pages
Color, fills, and transparency
Ultimate Vector Bundle Vol. 1
CorelDRAW Standard 2021
Ultimate Vector Bundle Vol. 2
Corel Vector
Comments (2)
Reader Interactions
Comments
Hello,
I have the latest version of Coreldraw 2022 and the ” Fit Object to Line isn’t in the Object drop down menu. How to I get this feature?
Hi Gene,
Are you using the Windows or Mac version of CorelDRAW 2022? The Fit Objects to Path command isn’t available on Mac, also not available if you are using CorelDRAW Standard instead of the full CorelDRAW Graphics Suite.
Best regards,
The Discovery Center team
