CorelDRAW lets you shape objects, including lines, artistic text, paragraph text frames, and bitmaps with envelopes. In this tutorial, you’ll learn how to use the Envelope tool to apply and modify an envelope that conforms to the shape of an object, such as shaping a logo to match the curve of mug to create a realistic mockup.
Thanks for watching! We hope you found this tutorial helpful and we would love to hear your feedback in the Comments section at the bottom of the page. You will find a written version of this tutorial below, and a printable PDF copy to download on the Download Resources tab above.
Start your FREE 15-day trial and embark on a design journey with powerful tools for vector illustration, layout, photo editing, typography, and collaboration.
Download these free resources:
Written tutorial (PDF, 567 KB)
CorelDRAW Graphics Suite Resources
Quick Start Guide (PDF, 2 MB)
Keyboard Shortcuts (PDF, 3.5 MB)
CorelDRAW and Corel PHOTO-PAINT user guides
For CorelDRAW Graphics Suite subscription and perpetual licenses (2018 to 2024), languages include English, Português do brasil, 简体中文, 繁體中文, Čeština, Deutsch, Español, Français, Italiano, 日本語, Polski, Русский
What’s New in CorelDRAW Graphics Suite
CorelDRAW Tools
![](https://learn.corel.com/wp-content/uploads/2022/11/CDGSSub-TYN-preview.jpg)
![](https://learn.corel.com/wp-content/uploads/2022/03/VectorBundle1-preview.png)
![](https://learn.corel.com/wp-content/uploads/2022/03/CDS-TYN-preview.jpg)
![](https://learn.corel.com/wp-content/uploads/2024/01/VectorBundle2-preview.png)
![](https://learn.corel.com/wp-content/uploads/2022/08/Widget_CorelVector_600x400.jpg)
How to Use the Envelope Tool in CorelDRAW
Envelopes are used to re-shape objects such as a curve, group of curves, artistic or paragraph text, or bitmap images, either by dragging the nodes that surround the object, or by fitting the object to an existing curve. Because enveloped are applied non-destructively, they can be edited or removed, and the original object is preserved.
Click on any of the images below to view full-size.
Envelope Tool Basics
The Envelope tool is part of the Effects tool group.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image01-191x300.png)
There is also an Envelope docker, or Envelope inspector on the Mac, which can be opened by going to Window > Dockers > Effects > Envelope. On the PC, the shortcut to open this docker is Ctrl + F7, and on the Mac it’s Shift + Ctrl + E.
The options in the Envelope docker are the same ones that appear on the property bar when the Envelope tool is activated.
Envelope Tool Modes
This example consists of a simple artistic text object. With the Envelope tool active, and the text selected, the property bar has four envelope modes. We’ll start with Straight line mode.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image02-300x105.png)
In this mode, corner nodes can be dragged both horizontally and vertically, and middle nodes can be dragged either horizontally or vertically.
For all envelope modes, holding the Shift key while dragging moves opposite nodes in opposite directions.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image03-300x110.png)
Holding the Ctrl key while dragging moves opposite nodes in the same direction.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image04-300x104.png)
Single arc mode works in a similar way. Dragging middle nodes produces arcs in one direction, and corner nodes produce arcs in either direction.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image05-300x108.png)
Dragging nodes in Double arc mode produces S-curves, in which the tangency at either end stays the same.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image06-300x118.png)
In all three of these modes, you can’t adjust curve tangency at any node. But you can do this in Unconstrained mode, which creates a freeform envelope. Unconstrained nodes can be used to reshape the envelope in ways that can’t be done in the other modes.
For example, you can:
- drag nodes anywhere
- drag arrows to adjust tangency
- select a corner node and change it to a smooth node
- select a smooth node and change it to a cusp node that can have different tangency on either side
- double-click to add nodes
- double-click a node to remove it
- drag to marquee-select a group of nodes to change or move them all at once
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image07-300x149.png)
To start over, or to remove the envelope, click the Clear Envelope button on the property bar.
Using the Envelope Tool to Create Perspective Objects
A simple application for the Envelope tool is to place an object in perspective. In this example, the banner shape and artistic text are a grouped object.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image08-300x248.png)
With the group selected with the Pick tool, and the Envelope tool active, you can use Straight line mode and drag corner nodes to match the side of the box.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image09-300x280.png)
Artistic Text Envelopes
Another common application is to fit artistic text to a shape. There are several presets listed in the Preset list dropdown on the property bar, such as Circular or Push Down. The Envelope docker has even more preset choices.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image10-300x109.png)
To fit the text to a shape, click the Create envelope from icon on the property bar. This will create an envelope that is based on the shape of another object – in this case, the cloud shape.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image11-300x206.png)
Then click the cloud to fit the text to. The envelope Mapping mode affects how the object fits to the envelope shape. Choose a mode from the Mapping mode dropdown list on the property bar:
- Original mode maps object corners, then maps other nodes linearly.
- Putty mode maps object corners only.
- Horizontal and Vertical modes stretch the object to the shape’s basic dimensions then compress in either direction to fit.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image12-292x300.png)
Even when the original curve is removed, the envelope is still applied. Our example now has some paragraph text added to the side. With the paragraph text selected, and the Envelope tool active, click the Copy envelope properties icon on the property bar.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image13-300x116.png)
After clicking the artistic text to copy its envelope, its cloud-shaped envelope is applied to the paragraph text.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image14-300x94.png)
Using the Envelope Tool to Create Realistic Mockups
Designers often need to provide their clients with mockups of branded items, and using the Envelope tool helps make these mockups look more realistic. In this example, we’ll use the Envelope tool to fit the logo on the right to match the perspective of the mug in the image on the left.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image15-300x169.jpg)
The first step is to select the logo with the Pick tool, move it approximately into place on the mug, and resize to fit.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image16-300x247.jpg)
After activating the Envelope tool, because we’re working with a basically rectangular object, you can simplify the envelope shape by double-clicking to delete the middle nodes.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image17-300x250.jpg)
Now you can drag corner nodes into place, and click nodes to adjust the tangency of the envelope shape.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image18-300x261.jpg)
Envelopes can also be used to fit a bitmap image to a curve. This example consists of a closed curve drawn with the Pen tool, and an imported bitmap image of a flag.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image19-300x218.png)
With the Envelope tool you can fit the bitmap to the curve, so that the flag appears to be waving in the wind.
![](https://learn.corel.com/wp-content/uploads/2022/02/CDGS-EnvelopeTool-Image20-300x227.png)
Reader Interactions
